Yellow Jackets Needed?
cowardm
Minneapolis, MN
On the RM100LB (Lynch Box) can you just change for any power tube type or do you need Yellow Jackets or something like that?
You can use any of the standard power tubes and variants 6L6/EL34/E34L/6ca7/KT7/KT66/6550/KT88/5881 with just a re-bias etc.
YellowJackets are only needed if you want to run EL84
cowardm said:
Yellow Jackets need for 6V6 as well?
nope...6v6 runs just fine...standard advice is only to use JJ...since you need a tube that can stand 500V+ on the plates.
