DC Widowmaker
New and boxed with original 6-pin/6-pin firewire cable, original packaging, manual and software. I'll even throw in a 4-pin/6-pin cable for free, at your request. I connected it up once but discovered that my laptop is inadequate, so seeing as I can't afford to buy a new computer, this has to go. Completely brand new, perfect condition, unused. Retails at ?385 everywhere so grab yourself a bargain. Delivery by courier: ?15, pickup: free. Non-UK, PM me for prices. Here's the info:
* FireWire (IEEE 1394) audio interface
* 24-bit resolution, up to 192 kHz sampling rate
* 18 simultaneous inputs and outputs FireWire audio interface
* 8 microphone preamps w/ trim control and individual phantom power switches
* 8 analog line Inputs including 2 Instrument Inputs
* 8 channels of optical ADAT I/O (4 ch. via 96k dual SMUX)
* S/PDIF I/O, AES/EBU I/O, MIDI I/O and word clock I/O
* Headphone output and Main output with volume control for monitoring purpose
* Channel meters on channel 1 to 8 for input or output
* Synchronization, sampling rate, digit I/O and MIDI in/out indicators
* Dual FireWire ports for daisy chaining and direct connection to Mac or PC
* Stand-alone Mixer functionality for field and studio use without computer
* Instrument input, pad switch, balanced TRS send jacks on Inputs 1 and 2
* Compatible with Windows XP / Vista and Mac OSX
* Steinberg Cubase LE 4 DAW software included
The new Phonic Firefly 808 Rack-mountable FireWire unit is an easy-to-use, high-quality interface for songwriters to record guitars, keyboards, vocals and more to the computer. Featured are 8 analog (XLR and 1/4") inputs and 8 analog (1/4") outputs, as well as S/PDIF, AES/EBU, MIDI and ADAT inputs and outputs - all of which are streamed to and from the computer in real time through the 24-bit/192kHz FireWire connection. Compatible with the most popular of Digital Audio Workstation software, this powerful unit provides recording musicians and engineers alike with the kind of sophisticated yet easy-to-use recording device they require.
