Jack Napalm
I am trying to setup my LB with a GSP1101 and the four cable method and I have everything working except I can't get the amp to change channels with the X15.
My setup is X15 midi Out to Midi In Amp. Amp Midi/Thru to GSP 1101 MIDI IN.
The GSP1001 will change channels appropriately but the amp will not.
When I plug the three button amp footswitch in it works and so does the GSP. Everything is set to channel 1.
I have tried holding the channel select switch down for a second but that doesn't work.
I also tried plugging the X15 into the GSP and then to the AMP and same results. Anybody done this before? I know I must be missing something simple.
