Ampoholic
RP1000 in perfect working order, brand new condition. Comes with original box, power supply & manual.
$235 shipped CONUS and PayPal GIFT!
DigiTech RP1000 Guitar Multi Effects Pedal with Integrated Switching Features:
Effect switching system offers control over external & internal stompboxes and effects
Exclusive Pedalboard Mode provides on/off and realtime control to any five RP1000 effects or parameters
Amp/Cabinet Bypass defeats internal amplifiers and cabinets in all presets
Built-in Phrase Looper
Built-in expression pedal controls the Digitech RP1000's Whammy, wahs, volume, and other parameters
Built-in chromatic tuner
Switchable Stompbox Loop for control of external stompboxes and effects
Switchable Amp Loop to retain your amp's tone
40 Tone and 40 Effects Libraries
200 presets (100 factory, 100 user)
Over 160 effects including stompboxes, choruses, delays, amps, and cabinets
Up to 5 seconds of delay time
24-bit/44.1kHz sample rate
All-metal construction
Heavy-duty metal switches for stompbox response
Bright LEDs display program status and effect on/off
Large 10-character LED display for preset name, bank name, and tuner
Independent 1/4" L/R outputs
Independent XLR L/R outputs with ground lift
Amp/Mixer switch optimizes 1/4" outputs for amp or direct-to-mixer connections
Stereo 1/8" headphone output
Downloadable X-Edit librarian software
2 x 2 USB audio streaming
Power supply included
Digitech's Integrated Effects Switching System takes multi effects to a whole new level.
The DigiTech RP1000 guitar pedal is loaded with over 160 effects and 200 presets giving you a splendid range of tones. With an integrated effects switching system, no longer will you have to do the pedal tap dance?just select your preset and your tone is engaged, just the way you like it. This DigiTech pedal comes with a built-in phrase looper with 20 seconds of record time. You can also route external effects pedals through it using the stompbox loop.
Your Amp
The Digitech RP1000 comes with an Amp/Cabinet bypass switch that allows you to turn off the RP1000's internal amplifiers and cabinets so your amp's tone stands alone.
Simplicity of a Guitar Pedal
Popular on the Digitech RP500, the RP1000 multi-effects pedal also features the Pedalboard Mode that turns footswitches 6 through 10 into stompbox-style effect on/off controls.
100 different Pedalboards
When the Amp/Cabinet Bypass is used in conjunction with the Pedalboard mode, the RP1000 turns into 100 different pedalboards. You get instant access to both preset changes and stompbox on/off control?truly the best of both worlds.
The DigiTech RP1000 pedal is built like a tank from a cast-metal chassis to the 14 vacuum-style switches. A large 10 character LED display makes for easy stage use topped by a built-in expression pedal to control wahs, volume, whammy, and other parameters.
Your sound is king; the control of your sound is imperative. The RP1000 pedal gives you added control to express yourself the way you want?no longer will the lack of control stand in the way of your expression.
Choose from the extensive list of guitar effects including:
Guitar Pedals:
Compressor / Sustainers based on:
Boss CS-2Compressor / Sustainer
DigiTech Main Squeeze Compressor
MXR Dynacomp;
Wah / Volume based on:
Dunlop Cry Baby Wah
DigiTech Full Range Wah
Vox Clyde McCoy Wah
Volume Pedal
Distortions & Overdrives based on:
SCREAMER (Ibanez TS-9)
TS 808 (Ibanez TS-808 Tube Screamer)
SPARKDRIVE (Voodoo Lab Sparkle Drive)
OD OVERDRIVE (Guyatone Overdrive OD-2)
DOD 250 (DOD 250 Overdrive/Preamp)
RODENT (Pro Co RAT)
MX DISTORTION (MXR Distortion +)
DS (Boss DS-1 Distortion)
GRUNGE (DigiTech Grunge)
ZONE (Boss MT-2 Metal Zone)
DigiTech Death Metal
GONKULATOR (DOD Gonkulator Ring Modulator)
8TAVIA (Roger Mayer Octavia)
FUZZLATOR (Demeter Fuzzulator)
CLASSIC FUZZ (DOD Classic Fuzz)
FUZZY FACE (Arbiter Fuzz Face)
BIG PI (Electro-Harmonix Big Muff Pi)
DigiTech Redline Overdrive
Amplifiers & Acoustics:
57 CHAMP ('57 Fender Tweed Champ)
57 DELUXE ('57 Fender Tweed Deluxe)
59 BASSMAN ('59 Fender Tweed Bassman)
62 BROWN BASSMAN ('62 Fender Brownface Bassman)
65 TWIN REVERB ('65 Fender Blackface Twin Reverb)
65 REVERB ('65 Fender Blackface Deluxe Reverb) 65 JTM-45 ('65 Marshall JTM-45)
68 SUPER LEAD PLEXI ('68 Marshall 100 Watt Super Lead (plexi)
68 JUMP PANEL ('68 Marshall Jump Panel)
77 MASTER VOLUME ('77 Marshall Master Volume)
83 JCM800 ('83 Marshall JCM800)
93 JCM900 ('93 Marshall JCM900)
01 JCM2000 ('01 Marshall JCM2000 (Solo Channel)
62 AC15 ('62 Vox AC15)
63 AC30 TOP BOOST ('63 Vox AC30 Top Boost)
69 HIGH WATTAGE ('69 Hiwatt Custom 100 DR103)
81 MARK IIC ('81 Mesa Boogie Mark II C)
01 DUAL RECTIFIED ('01 Mesa Boogie Dual Rectifier)
99 LEGACY VL-100 (Carvin Legacy VL-100)
96 MATCH HC-30 ('96 MatchlessTM HC30)
88 SLO-100 ('88 Soldano SLO-100)
Gibson GA-40
Peavey 5150 II
Roland JC-120
Sunn 100S
Randall HT-100
DigiTech Solo
DigiTech Metal
DigiTech Bright Clean
DigiTech Chunk
DigiTech 2101 Clean Tube
DigiTech Crunch
DigiTech Blues
DigiTech Fuzz
DigiTech Spank
DigiTech High Gain
DIGITECH MONSTER - Maxed-out gain
DIGITECH "TWEEDFACE"?Tweed preamp w/Blackface poweramp
DIGITECH "65 Blackface Bassman"?'65 Blackface preamp w/ Bassman poweramp
DIGITECH STONERROCK?Thick, sludgy distorted amp tone
DIGITECH DARKMETAL?Responsive, tight metal tone
DIGITECH TRANSISTOR?Solid state transistor amp sound
DIGITECH BROWNSOUND?Hot rodded 80's stack tone
DIGITECH MOSH?Chunky metal tone with just the right amount of sizzle
2101 CLEAN TUBE DigiTech GSP2101TM Artist Clean Tube 2101 SATURATED TUBE DigiTech GSP2101 Artist Saturated Tube
DIRECT No amp model
DREADAUGHT ACOUSTIC
JUMBO ACOUSTIC
Cabinets:
CHAMP 1X8 (1x8 '57 Fender Tweed Champ)
DELUXE 1X12 (1x12 '57 Fender Tweed Deluxe)
DELUXE REVERB 1X12 (1x12 '65 Fender Blackface Deluxe Reverb)
BRITISH 1X12 (1x12 '62 Vox AC15 w/20W Vox Speaker)
BLONDE 2X12 (2x12 '57 Fender Blonde Bassman)
TWIN 2X12 (2x12 '65 Fender Blackface Twin Reverb)
BRITISH 2X12 (2x12 '63 Vox AC0 Top Boost w/ Jensen Blue Backs)
BASSMAN 4X10 (4x10 '59 Fender Tweed Bassman )
BRITISH 4X12 (4x12 Marshall 1969 Straight w/ Celestion G12-T70)
GREENBACK 4X12 (4x12 Marshall 1969 Slant w/ Celestion 25W Green backs)
FANE 4X12 (4x12 Hiwatt Custom w/ Fane Speakers)
BOUTIQUE 4X12 (4x12 '96 VHT Slant w/ Celestion Vintage 30's)
VINTAGE 4X12 (4x12 Johnson Straight w/ Celestion Vintage 30's)
4X12 4x12 DigiTech Solo
2X12 2x12 DigiTech Bright
4X12 4x12 DigiTech Metal
4X12 4x12 DigiTech Rock
4X12 4x12 DigiTech Alt Rock
4X12 4x12 DigiTech Vintage
4x12 DigiTech Chunk
4x12 DigiTech Spank
4x12 DigiTech Speaker Compensation
DIRECT No cabinet model
FX Models:
Chorus Stompbox Models based on:
Boss CE-2 Chorus
DigiTech Dual Chorus
DigiTech Multi-Chorus
TC Electronics Chorus
DIGITECH GLISTENING Chorus
Flanger Models based on:
MXR Flanger
DigiTech Triggered Flanger
Electro Harmonix Electric Mistress
ADA Flanger
Phaser Models based on:
MXR Phase 100
DigiTech Phaser
Electro Harmonix Small Stone
Pitch Models based on: DigiTech Whammy
DigiTech Pitch Shift
DigiTech Detune
DigiTech IPS
Boss OC-2 Octaver
Vibrato / Rotary Models based on:
DigiTech Vibrato
DigiTech Rotary
DigiTech Vibro / Pan
Unicord UniVibe
Tremolo Models based on:
DigiTech Tremolo
DigiTech Panner
Fender Opto Tremolo
Vox Bias Tremolo
DigiTech Scattertrem?Dual tremolo effect
Envelope / Special Models based on:
DOD FX25 Envelope Filter
DigiTech Auto Yah
DigiTech YaYa
DigiTech Synth Talk
DigiTech Step Filter
DigiTech Sample & Hold
Delays:
Digital Delay
Analog Delay
Pong Delay
Modulated Delay
Tape Delay
Reverse Delay
DM Analog Delay - based on Boss DM2 Analog Delay
Echo Plex - based on Maestro EP-1 Tube Echoplex
Reverbs based on:
Lexicon Ambience
Lexicon Hall
Lexicon Room
Lexicon Studio
EMT Plate - based on EMT 240 Plate Reverb
Spring - based on Fender Twin Reverb
Your Amp
Guitar Pedals:
MXR Dynacomp;
Dunlop Cry Baby Wah
Vox Clyde McCoy Wah
Volume Pedal
RODENT (Pro Co RAT)
Gibson GA-40
Peavey 5150 II
Roland JC-120
Sunn 100S
Randall HT-100
DigiTech Solo
DigiTech Metal
DigiTech Chunk
DigiTech Crunch
DigiTech Blues
DigiTech Fuzz
DigiTech Spank
DigiTech High Gain
DIRECT No amp model
DREADAUGHT ACOUSTIC
JUMBO ACOUSTIC
Cabinets:
4x12 DigiTech Chunk
4x12 DigiTech Spank
FX Models:
Boss CE-2 Chorus
MXR Flanger
ADA Flanger
MXR Phase 100
DigiTech Phaser
DigiTech Detune
DigiTech IPS
Boss OC-2 Octaver
DigiTech Vibrato
DigiTech Rotary
Unicord UniVibe
DigiTech Tremolo
DigiTech Panner
Fender Opto Tremolo
Vox Bias Tremolo
DigiTech Auto Yah
DigiTech YaYa
DigiTech Synth Talk
Delays:
Digital Delay
Analog Delay
Pong Delay
Modulated Delay
Tape Delay
Reverse Delay
Reverbs based on:
Lexicon Ambience
Lexicon Hall
Lexicon Room
Lexicon Studio
