Mattfig said:I would recommend a sonic maximizer or EQ to add back that low end...Some people may tell you that certain EL84 brands have more low end than others and thatl may be the case- but that difference is probably not enough of what you are looking for...
To start, drop the prescence and raise the density to taste...That can be a good start as those controls are helpful and sensitive...
rblyn said:Mattfig said:I would recommend a sonic maximizer or EQ to add back that low end...Some people may tell you that certain EL84 brands have more low end than others and thatl may be the case- but that difference is probably not enough of what you are looking for...
Matt is correct...El84's in general will not give you much low end. EQ's will cetainly help or possibly goin to a 2x12 cab.
rblyn said:Matt is correct...El84's in general will not give you much low end. EQ's will cetainly help or possibly goin to a 2x12 cab.
chuckmehh said:What exactly is sag? I always hear it referenced but never really understood the tone.
