Shinozoku said:Mike P said:Shinozoku said:Hey Mike, would you happen to have tried the higher wattage M75's in comparison to the regular 25 watters?
Yes. I actually prefer the 65 watters because I like a little headroom but it's hard to "go wrong" with either. I also prefer the bigger dustcap even though he doesn't believe it makes much difference.
Awesome Aside from the headroom, are there any noticeable tonal differences? Or does it basically just sound like a killer pre-rola Greenback with more headroom? I was wanting to make a 2x12 for my Randall with dimensions based off of a Framus Cobra cabinet, and didn't want to worry about the added smoothness of the Eminence versions, etc. Also don't wanna blow up my speakers So I've been searching for a higher wattage Greenback replacement that will get me the same tone so I don't have to lug around a 4x12.
I have a producer friend that has the Pre-Rolla's in an old Marshall cab and the 65 watt Scumback's in another cab and the difference is negligible, if not inaudible. They're that good.
In a side by side comparison, I slightly prefer the larger dust cap because I feel that it's every so slightly smoother on the top end. That said, I'm ridiculously particular (probably to a fault) and in the end, you can't go wrong with either.
On a side note, I find that the Bogner 2x12 is among, if not the best, 2x12 cabinet for Classic Rock/Modern Rock/Metal that I've heard, with the Mesa/Boogie 2x12 a close second. Both use Marine Grade plywood with the proper finger joints, etc., just in case your interested in an alternative.
