webrthomson
frigolajm said:I'll definitely take one. Just need a bit more info on how to hook up my processor without an effects loop. Also are the dual channel modules switchable via midi? Not switching between modules, but switching between channels.
Yes you can switch between channels on a given module via midi, or indeed from module 1 channel B to module 3 channel A etc.
In terms of effect loop, it a bit of a redundant question for rack gear like this as you would either place your effects before (think rack wha) or after (delay etc.) but before power amp.
If you want to do anything more advanced or to move the other units out of the signal path you would need a switching system like a Bradshaw or GCX system - depends on what you are trying to achieve - why not give us some idea and we can chip in our thoughts?
