After several configurations and testing:
Mine in a nutshell is as follows: 3 RM4s and an RT2/50 as the core....My preamp tubes in the RM4s are straight TungSolECC803 Gold Pins across the board for both the PI and Loop...
Effects are: Lexicon MX200, Rocktron Pro EQ (is set for each module to have it's own EQ settings via MIDI), TS808
Noise Control: ISP Gstring Decimator Pedal - AMAZING!
Tuner: Peterson StroboRack
Power: Two Furman Power Conditioners w/voltage readings and full protection as well as a Tripp Lite Voltage Regulator and Backup Power Supply which buys me a few minutes in the event of a power outage to shut everything down properly...Also reduces noise...
Controllers: Voodoo Labs GCX Guitar Audio Switcher and GCP Ground Control Plus to control all modules, EQ, effects, etc with the push of one button I can change everything! It's awesome...
Power Tubes in RT2/50 are SED "Winged C" EL34s and TAD 6L6GCs...Also run TungSol 6550s sometimes as well as JJ EL34s...
In the Serial Loop are Alesis 3630s- don't use the gates, just compression...Each RM4 has it's own 3630 to keep things simple for me...Plus 3630s are cheap and pretty good for what I use them for...Volume attenuation and VERY VERY VERY slight compression on occasions....
In each module:
Figmods Clean
V1 - JAN GE 5751
V2 - JAN GE 5751
Twinface
V1 - JAN GE 5751
V2 - JAN Sylavnia 12AX7WA
Figmods Top Boost
V1 - TungSol12AX7
V2 - JJ ECC803
XTC - Sacred Groove modded Blue/Red
V1 - JAN Philips 12AX7WA
V2 - TungSolECC803GoldHG*
Mashall Plus
V1 - TungSolECC803Gold
Benzin
V1 - Penta12AX7M
V2 - Ruby12AX7AC5HG+*
Terrier (soon)
V1 -
V2 -
Scorch
V1 - JJECC803S
Salvado Dlx
V1 - Penta12AX7M
V2 - TungSolECC803HGGold*
Chem Angel
V2 - Ruby12AX7HG+*
Figmods Erecto
V1 - JAN Philips12AX7WA
Mamba
V1 - JAN Sylvania12AX7WA
V2 - JJECC803HG*
***The tubes with HG mean rated at High Gain...Great in V2, awful in V1....
Cabs and Speakers
Ampeg 412 loaded with Celestion Vintage 30s
Randall 412NXT loaded with Celestion Neodymiums made specifically for the MTS line...Pricey but awesome....Also has updated cabinet simulation built in which is fun to mix lightly with the mic'ed speakers...Provides slight definition and are almost as good as some IRs I've played with...It's easy to use so I use it...Not for primary sound, but more as a filler, if that makes sense...
That's about it, hope it makes sense...I've done a lot of edits as my copy and paste from another program was a mess...
In each module:
Figmods Clean
V1 - JAN GE 5751
V2 - JAN GE 5751
Twinface
V1 - JAN GE 5751
Figmods Top Boost
V1 - TungSol12AX7
V2 - JJ ECC803
Mashall Plus
Benzin
V1 - Penta12AX7M
Terrier (soon)
V1 -
V2 -
Scorch
V1 - JJECC803S
Salvado Dlx
V1 - Penta12AX7M
Chem Angel
V2 - Ruby12AX7HG+*
Figmods Erecto
Mamba
V2 - JJECC803HG*
Cabs and Speakers
