MarcoR
The volume on the effect level is post, the master volume on a module is the pre send level.seanh303 said:Oh, ok, I thought you were running multiple rackmount eventides! As far as the pedals go, I think it's basically no different than running through a Gmaj or other effects unit that will handle 100% of the serial signal and then use built in or added drykill, or any other pedal board setup...works/sounds fine with a serial connection.
seanh303 said:Eclipse and some other rackmounts (H-series, probably PCM96 etc.) really need a parallel connection to make the most out of it.
You're missing my point; I've created three parallel loops. Sure, having a parallel loop built into your pre amp is a convenient way to run a SINGLE unit in parallel but what if you want to add another unit in parallel?
seanh303 said:This Tech Note explains it better than me, but basically, you need to have you dry signal seperate from your wet signal, run across +4db balanced connection to the XLR ins/outs of the rackmount.
This is exactly what I'm doing minus the XLR connectors.
seanh303 said:MTS amps are freakin' perfect because they have series AND parallel loops, and switchable between -10db and +4db....they're one of the most versatile amps I've yet found hands down...still pissed they discontinued them, incredible potential!
The loops are convenient but in a more complex rig you'll likely need a switcher and a mixer. I have both RM4 and M4 and the loops are useless to run multiple effect in parallel besides the fact that the RM4 and M4 are in a separate switcher to toggle between the two.
Bottom line is to do what you want to do, you will need a third party parallel loop interface like the Suhr Minimix II parallel effects loop. There was an Egnater custom parallel loop device floating around for a while.
