djdayson said:
Dude...
Console EQ is post EQ, 2 Buss EQ is post EQ, Mastering Engineer's use EQ on the mix, etc.
Oh, just gimme a break.
You stated clearly that "nearly EVERY recorded tone you've heard has been EQ'd" and now you want to including Mastering EQ?
First off, I'm not into 2 buss or mastering EQ. If you record your tracks correctly and choose the "right" mic, mic preamp, etc. for the job, mastering EQ is unnecessary. As a matter of fact, many artists in the past decade have chosen NOT to master their works.
And decades prior? EQing was up to the artist, producer and mastering engineer. But that's a far cry from stating that "every tone, blah, blah, blah".
I'm curious: How many releases have you heard pre-master? Which ones and how much difference did it make?
djdayson said:
A HP Filter is EQ, and you even say you use them?
Depending on the source and the mic choice, a HPF is helpful to create space for other instruments. But that is NOT changing the fundamental tone of a an instrument, whether it's a guitar, bass, saxophone, etc., which is contrary to your original post.
djdayson said:
I don't question anything about you except for your misconceptions about EQ in general, and your mis-guided attempts to paint EQ as evil due to freq based phase shifts. There are young people here that might believe that BS. You really think you hear freq based phase shifts on a electric guitar track in the mix?
Evil? No. Unnecessary? Yes.
Once again, if you choose the right mic, preamp, guitar, strings, pickups, etc., there should be absolutely NO reason to EQ and/or especially radically EQ a guitar for a "normal" mix (I'm not referring to a special effect such as a telephone, AM radio, etc.).
If you can't get a great tone to your DAW or tape with just a guitar and amp, then something has failed in your chain.
djdayson said:
I'm not just talking only about EQ in a guitar rack, I'm talking about the entire record chain, most specifically console and plugin EQ on the tracks in question, comprende?
Once again, if a source is recorded properly with the mix in mind, little to no EQ is necessary. And "plugin EQ"? I own just about every plugin bundle ever made and I'd never use "plugin" EQ on guitars or bass. Yuck.
djdayson said:
Why in the world should I even consider getting to a childish pissin' match with someone like you on an internet forum? I have more important things to do with my time, so good luck to you, and twist that console or plugin EQ on a guitar track just once for me LOL!
First off, you're the one that started this, by questioning MY credits while providing absolutely NONE of your own. Secondly, your statement was and still is unequivocally untrue.
Furthermore, I prefer to record my instruments properly and get the proper sounds while recording. It makes delivery of my masters much quicker and efficient, especially since I'm often times on a tight schedule.
And once again: Have you provided your credits and tracks? I'm not the only person who is curious to hear your work.
