Kapo_Polenton said:Another thing.... while I do feel that dialing more treble in on an amp sounds more natural than using post EQ, I think we can all accept the fact that some players make EQ a definite part of their tone. VH with his MXR 6 band or GE-10.. Lynch STILL using that GE-10 on his board. Prior to the AFD amp, Slash was still using EQ pedals to boost the mids in his leads during the Use your Illusion stuff (not according to me, according to gear sites), Michel Shenker used to use the cock'ed wah. That is a form of EQ.. it works.
I declare this argument a tie! lol 8)
1. Dial in the best tone you can get from your amp ( the beauty of re-amping really if you want to go back and do it)
2. Apply EQ sparingly where you might need it.
3. As long as the artist is happy and people tell you the finished product kicks ***, your job is done.
4. Good luck getting killer REAL acoustic drum sounds from scratch without some EQ. That click on the kick drum doesn't just come from proper mic placement, microphones, and environment.
5. Nobody's recordings on here will be able to match Mike P's because A. his gear is better than most people's, B. he has experience.
Reamping is a cop-out, IMO. Dial it in, make a decision and go.
As for drums, if you use the "right" mics and mic pre's (again, a properly equipped studio) AND the right drums (Tama or Yamaha Oaks, for example) and the "right" heads, you can get away with very little EQing.
That said, drums are different than guitars, IMO. It's pretty easy to capture a great tone and roll with it. Bass, too. Drums require a little more work at times because they're the foundation upon which a mix is built. But once the drums are dialed in, it's pretty easy to lay just about anything on top with little to no EQ.
Unless of course, you're making a "Creative" choice. But unless you're talking about a producer whose name rhymes with Moe Parcheesi, the majority of us go for general production techniques.
