MarcoR said:
I go out the M4 into a switcher that splits my signal and sends to my Eventide units. Then out the Eventide's in stereo to a RJM mini line mixer then to the RT2/50. All the Eventide units are set to killdry and I can run this in mono, stereo or wet/dry/wet.
How many eventides are you running? So using 1/4" analog connections throughout the whole chain? Probably a dumb question, but what do you suppose the average output db is of the M4 outs?
Very interesting setup. Also, are you using the parallel outputs, with one going to the effects and the dry going straight to the power amp?
